16" wheels and 205/55-16 tires will fit on a mk5 GTi just fine
hello, i know this might get trashed and cause its my first post but here goes..
im looking to get a set of steel rims and a set of winter tires for my gti, called the dealership by where i live and he said since i have the 18" stock rims that they cant fit the car with a set of steels..? he said they would have to end up doing some mods to make it fit..
That is simply incorrect.
US mk5 GTi with factory 18" wheels comes with a 16" steel wheel and 205/55-16 tire stock,
it is the spare tire.
No way you would have to make a modification to a stock setup to mount the factory spare tire.
now i keep reading everywhere that a 16" rim w/ 205/55r16 on them should fit.. Any truth to this or am i really s.o.l.?...
True.
Some may point out the factory spare has warning labels
much like those found on a mini spare / doughnut. But it is not one of those.
Factory spare is a standard steel road wheel
with a VW part number
and a standard H rated all-season tire
The labels are due to handling and braking changes that would result from the contact patch
and tire construction / compound mismatch when running one 16" and three 17" or 18" tires.
OE VW 16" x 6.5" steel wheel (6.5Jx16H2 ET50) [VW PN 1K0 601 027 A] - 205/55-16 91H Continental ContiProContact
VW lawyers + US tort laws = warning labels for the obvious
As long as all four 16" wheels and tires are matched, you will be fine.
Comparing same make and model winter tire,
in inclement conditions
a 16" high profile / smaller contact patch tire will significantly outperform
an 18" low profile / larger contact patch tire.
And the savings on a 16" winter tire vs an 18" winter tire of same make and model
should typically cover the cost for the 16" wheels.
Been running 16" winter tire since the day I bought the car.
Before closing the deal, I purchased a set of 16" alloys off forum classifieds,
new set of winter tires from TireRack.
Had them mounted and balanced and put in the back seat of my trade-in.
Took delivery in Feb in MI, had the 18" wheels with
summer rubber
removed and placed in the back and the 16" wheels and snow tires
put on the car at the stealership before driving my new car off the lot
(for a 300 mi trip home in a snow storm).
My 2006 US GTi with the first set of 16" winter wheels and tires
purchased in haste a few days before buying the car.
OE VW 16" x 7" Vancouver (7Jx16H2 ET37) [VW PN 3B0 601 025 T] - 205/55-16 91H Dunlop Winter Sport M3
My current set of 16" winter wheels and tires purchased at my leisure for a low $40 each (May 2007)
OE VW 16" x 6.5" Ditto (6.5Jx16H2 ET50) [VW PN 1K0 601 025 BC] - 205/55-16 91H Dunlop Winter Sport M3
