1 - 10 of 10 Posts
Super Moderator
I am looking to replace the rear bearings as i did my fronts already thinking it was the issue causing a vibration and a noise. I had it checked and it was definitely the back right bearing. I would like to know if the bearings in this link
http://www.mjmautohaus.com/catalog/...ng_and_Hub_Assembly_Rear_OEM&products_id=4075
would fit my car? Thanks for any advice !!
Check these out. Those do not say for a gti so i would not chance it based on price. I just did my left rear in my driveway in about 30 minutes. Make sure you get a M16 tripple square tool.
http://store.034motorsport.com/worl...e_id=241457&position_id=30&model_id=30306&QA=
sent from my phone bytchs
Hey i went with the skf on ebay actually found a great seller who sells skf i already purchased both rears. I believe skf is what vw has swapped to now correct menif im wrong but its actually 2 dollars or 3 cheaper than the *** with free shipping. Not sure if you live in the states or what not but if you do believe its free shipping. They are both genuine il provide the link below
http://www.ebay.com/itm/170843848922
I went with *** @ $89 each ←(included 10% off sowo discount) from urotuning. Should be here in a day or so ;)
Yep...online discount
Replaced the rear bearing with SKF and all is good now. Was easy enough if you have a 14mm and 18mm triple square. I found that the bearing bolt's head was bent, likely in the 2011 wreck, and went undetected during those repairs.
1 - 10 of 10 Posts
