Here is my problem last night I installed the Forge Blow Off Valve adapter...
I installed this last night... though I ran into a problem. The electrical sensor that you put the adapter between has a spring on it.. well when I was pulling it out the spring fell off and went somewhere in the engine and not on the ground. I spent hours searching for it with no luck. Even with out the spring inside it still has a fair amount of resistance so I put it all back together without the spring.
My question: Is there a place that has some sort of detailed diagram of everything so I can find out the name of this part? And is there a place that get this part at so I can replace the spring? And lastly, do with think any damage wiill be caused without this spring for the time being until I can find another part?
Thanks in advance
Thanks in advance
