i have a VW GTI 2001. 1.8L ADW engine.
my engine light is on and i get these codes.
Chassis Type: 17 - VW Golf Citi
Scan: 01,09,15,17,25,56
Address 01: Engine Labels: 06A-906-032-AVC.LBL
Controller: 06A 906 032 CM
Component: 1.8l 5V 110kW TLG02 V005
Coding: 06530
Shop #: WSC 05224
12 Faults Found:
17521 - Oxygen (Lambda) Sensor; B1 S1: Internal Resistance too High
P1113 -- 35-10 - - - Intermittent
17634 - Fuel Injector for Cylinder 2 (N31): Short to Ground
P1226 -- 35-10 - - - Intermittent
17648 - Fuel Injector for Cylinder 4 (N33): Open Circuit
P1240 -- 35-10 - - - Intermittent
17640 - Fuel Injector for Cylinder 8 (N86): Short to Ground
P1232 -- 35-10 - - - Intermittent
17838 - Circuit for Brake Vacuum Pump: Open or Short to Plus
P1430 -- 35-10 - - - Intermittent
17969 - Quantity Adjuster (N146): Control Deviation
P1561 -- 35-10 - - - Intermittent
17531 - Fuel Trim Air; Bank 1 (Add): System too Rich
P1123 -- 35-10 - - - Intermittent
17849 - EGR Valve (N18): Open Circuit or Short to Ground
P1441 -- 35-10 - - - Intermittent
17830 - Secondary Air Injection Solenoid Valve (N112): Short to Plus
P1422 -- 35-10 - - - Intermittent
18023 - Engine Oil Temp Sensor (G8): Implausible Signal
P1615 -- 35-10 - - - Intermittent
16811 - Catalyst Temp Sensor; Bank 1 (G20): Short to Ground
P0427 -- 35-00 - -
Readiness: 0010 0001
Address 15: Airbags Labels: 6Q0-909-605-VW5.LBL
Controller: 6Q0 909 605 A
Component: 12 AIRBAG VW5 02 0004
Coding: 12594
Shop #: WSC 01317
1 Fault Found:
00532 - Supply Voltage B+
07-10 -- Signal too Low - Intermittent
the things i noticed that my car does is that it started making some weird noise when i accelerate. it seem to be coming from the right side of the engine. also, when im on the freeway going about 70mph the car stops going for a few seconds then it goes again.
any help on what to do or if there is a simple fix would be helpful.
Coding: 06530
Shop #: WSC 05224
12 Faults Found:
P0427 -- 35-00 - -
Coding: 12594
Shop #: WSC 01317
1 Fault Found:
