The only thing that's changed is the forge DV... my boost gauge is on order. I'm having a hard time believing it's 30psi, but that's what the numbers from vag-com say.GTfly said:i dont think the stock wastegate will let you run 30psi if it has not been tweaked.
That can't be right!?! At least, I hope it's not, you'll pop that 2.0 like a balloon!Dragon said:The only thing that's changed is the forge DV... my boost gauge is on order. I'm having a hard time believing it's 30psi, but that's what the numbers from vag-com say.GTfly said:i dont think the stock wastegate will let you run 30psi if it has not been tweaked.![]()
I had one of our race team mechanics 'splain it to me... the reading does not take into account normal atmospheric pressure of about 14PSI.22350 said:That can't be right!?! At least, I hope it's not, you'll pop that 2.0 like a balloon!Dragon said:The only thing that's changed is the forge DV... my boost gauge is on order. I'm having a hard time believing it's 30psi, but that's what the numbers from vag-com say.GTfly said:i dont think the stock wastegate will let you run 30psi if it has not been tweaked.![]()
I've got the SPS controller to play with, now that I know I'm not killing the motor. :teethGTfly said:at peak? like at a spike? you should hit 20-22 spiking
