Sportech is a South African tuner with a penchant for German cars. Out to build the fastest GTI around, they are currently working on a people's missile called the P Cubed Golf. It will have, among many other things, 335 hp, and is being built to handle just as well as it flies.
Somehow they plan to wring those 335 ponies from the turbocharged 2.0-liter that hauls the GTI, but Sportech hasn't said how they'll do it. If they pull that off, they expect a top speed in excess of 150 mph. And because apparently there isn't much to do when traveling at Mach 0.2, inside the car will be an 1,800-watt Rockford Fosgate system, three 7-inch touchscreens, two tablet PC's for the back seat passengers, wireless Internet, and a DVD screen and 15-inch sub in the trunk. Oh, and the rear bench is swapped out for twin Recaros that match the ones in front.
According to Sportech's Chad Wentzel, the paint job is meant to "make more than a few heads swivel with its dramatic looks." If you happen to be in South Africa on April 27, you can check it out at the Castrol Extreme Show. Mach schnell indeed.
