1 - 15 of 15 Posts
Ive been looking to upgrade my GTI VR6 with either a supercharger or a turbo?
i cant decide which one to get, any ideas?
really?,
turbos are known for getting pretty hot under the bonnet.
and I've been doing a little research and it seems to me that both have high chances of royally screwing up my engine..
Is the risk worth the reward?
really?,
You want to spend 5k+, to do it right?
If not then it isn't worth it... a lot has to go into it.
Discussion Starter · #7 ·
yeah. [suicide]
not really up for that right now.
if i had 5k+ to blow I'd go get an mk1...
i'll just stick with suspension, exhaust, and intake for now.
supercharger = sexy sound
turbo= best efficiency
neither will be reliable unless you keep it at low boost.
I would go turbo, head spacer, low boost, larger injectors, tune? so many boosted vr's out there I'm sure there is a good one
wait.. this is a 24 valve obd2..
I would look on vortex at the technical forum for forced induction to see what you would be getting into.
I'm sure you could run 6psi on stock motor with a tune and injectors, more than that I think would need head spacer.
1 - 15 of 15 Posts
