Does anyone know if there is a way to reprogram the stock keyless entry (the remote key part itself) such that I can use it with a remote starter?
/Begin speculation
I would assume that it would have to be done using a VAGCOM. My thought is that you could set it up so that if you hold down a specific button on the remote for a specific length of time, you could send a signal to the car which would in turn signal the remote starter to do its thing. Of course the signal being sent to the remote starter would have to be set up in the car some how, but I have no idear how. I know that the option to open/close your windows using the remote is already built-in and simply needs to be activated, but using the same line of reasoning, can a separate function be built into the remote and car? Since there is no pre-set bit in the car's software for a remote starter (like the one to open/close windows from the remote) , does anyone know of any "spare" or "dummy" bits in the software that can be used (and programmed using the VAGCOM tool) to send a signal to the remote starter to do what I'm trying to?
/End speculation
I've googled this topic and it seems a lot of the older Vdubs were reprogrammable...but didn't see anything for the MKV yet.
I'd rather not have to go back to the dealer and spend $$ for them just to give me a new key with a starter button.
/Begin speculation
/End speculation
