1 - 17 of 17 Posts
Hey everyone.
I have a check engine light on for a engine temp running too low, a p3081. I checked my coolant sensor and its a black one, not a green one. So that could be the problem. My temp gauge, has never shown any issue. Its always dead center after warming up and always stays there. But some wierd symptoms have me concerned. SCENARIO: I get up bright and early, drive to university. Cars been off for the night. Everything is fine. Starts beautifully, drives smoothly. Go to class. Come back to the car 7 hours later. Same deal, everything is perfect. It gets tricky when the car is off for only a short time and then started again. I then get the following symptoms.
1. Weak start, I can best describe it as the car "burbling up to revs"
2. Sometimes the revs are irregular. They hover between 1 up to 1.25.
3. If 2. happens, the car rides choppy for the first few minutes of driving, then evens out and everythings fine.
4. This has hapened to my twice. The car wont start initially. Starts after cycling the ignition then giving it gas. Then starts with a gassy smell in the air.
It could be multiple problems. As I'm assuming. CEL has been on for a little while, symptoms just started popping up recently.
Thanks.
I'd replace the sensor and go from there. If it's anything like the black temp sensor on vr's, your symptoms are minimal and quite lucky. Most vr motors barely run when that sensor goes bad.
temp sensors go all the time on 1.8t's and VW's in general, I think you are supposed to replace it with a green top or brown top sensor that is better
Green top
Did you read the link I posted
It says possible cause
Bad temp sensor
Tapatalk This
Bad temp sensor
Tapatalk This
Some people don't think coolant sensors would have this kind of effect.
Sent from my Transformer TF101
1 - 17 of 17 Posts
