I posted a similar message on the DIY oil change, but want to make sure it is seen by anyone with a question on oil. I was talking with a friend that is a Master Craftsman certified by VW. He is German, and loves running his VW on the Autobahn (Passat, don't hold it against him.). He made a good point on the oil. Bottom line is "Don't deviate at all from what the manuafacturer recommends.". Use 5 - 40 Full synthetci (he recommended Castrol). Why? Your turbo spins at ~ 50,000 rpm. Think abut that for a second. Your turbo is turning almost 1000 rpm per second! I know, yeah yeah, so it turns fast... Heres the don't mess with the oil part. There are no bearings for the turbo shaft. It relies 100% on your oil to keep it from going metal to metal and seizing. the higher viscosity provides a better hydrostatic float. the oil is more expensive, but on the bright side, he said in Germany they go ~ 10,000 - 12,000 miles between oil changes (he said 20,000 kilometers). Hope this helps.
