Negative steering roll radius (NSRR): NSRR can be envisioned by viewing a car from the front and drawing an imaginary line downward through the ball joints. When the imaginary line hits the ground outside of a tire's centerline, the front suspension is said to have negative steering roll radius. Negative steering roll radius helps offset the sudden steering pull when, for example, a tire goes flat.
