1 - 3 of 3 Posts
· Use Google Search!!!!
have lights on like abs,airbag,steering,traction control after a subwoofer install :mad:
You need to check your stereo wiring. Obviously that caused the problem, right? unplug your battery for 20 minutes and see if they go away. if they come back, I would think you boogered the wiring
if you happened to unplug your hazard switch (in a mkv) you also unplugged your airbag warning light with it... therefore it will throw an airbag light on the dash... as for the others, if you disconnect a battery sometimes a bunch of the systems will throw lights at first, but once you drive for a few hundred feet at a speed faster than 5 (or 15, i can't remember) mph they will reset... i've had that happen to me before actually... otherwise, like xcrazydx said, something's wrong with something you did...
1 - 3 of 3 Posts
