Today I was driving and my temp wnt to 100 brfore I turned it off my rad fans wont kick in I was told to replace the fans (both) they are like $500 plus install anyone know what else it could be i'm new on the forms
Like you said check your fuses and see if on the fan area if any plug came disconnected. If all is good see if you can get it scanned by vagcom (preffered method) or a scanner and see if there are any codes that get show up. Post back here with any results.I'm thinking it may be a fuse or sensor or switch has anyone had this happen to them or know about this problem again both dont trip on I held idle at 2000 for a few mins to see if it they would go on and nothing. It was +30 in T.O today
yep ^check fuse, relay, power at plugs
you can jump the plug to make sure the fans work
