hey my post count tells all but I recently got a 2002 gti with the 1.8t 5 speed (107k miles) and the other night the clutch started slipping under moderate acceleration. then the next morning it got worse so i pulled over to check it out and i went to take off again, put it into first (using the clutch), let off the pedal and bam...nothing happened. engine didn't even bog down/move. last night we went to take another look with my father and we found the same result except when we put it in reverse the motor jumps like its engaging but nothing. the clutch pedal is soft as a baby's bottom all the way to the floor. also we have no record of the clutch being replaced by previous owners (2 of them) is that about the life span to expect from it..? any ideas?
thanks ahead of time!
