Hey guys, my car is leaking coolant from this hose connected to the resevior which has a y-shaped connector that is connect to two other hoses. The y-shaped connector has the leak, none of the hoses are affected and the source of the leak is the y-shaped connector. So, if anybody has info on this part, like part number or what it is called so I can go to the stealership and order it. Thank you in advance.
Here is a picture of what i am talking about: vw hose.jpg
Try here http://keffervwparts.com/parts//?siteid=216177 Hose flange to heat exchanger?
Select your year, click make, click model, choose cooling system, scroll down a bit to see diagram on left. Find that lil' bastich and your good to go.
Should only be a $20 part.
O0
