1 - 6 of 6 Posts
My '07 GTI shuts off power to the two DC power outlets when the ignition is shut off.
Is there a way to keep them hot at all times like in my '03 Turbo S ?
Is it a Vag Com adjustment or something else?
Chuck27
Dude
Im an engineer and I like to think in simple terms.
If you want a 12v outlet to always be hot, run a hard two-wire from the battery, through a new fuse in the fuse box, and on to the desired outlet. Might require a retarded double jointed elf, but not much talent or ninja schematic skill.
Fuse depends on practical application, but a 5 or 10A will handle most consumer electronics with ease.
Chris
Well I work in the engineering field too. From my experience our "simple" is considered "complicated" by the rest of the world. But I do have to hand it to you on this one as this is the appropriate non complicated solution.
+1
This is the "easiest" solution.
Hell that seems easy. Lol
USING MY PHONE BYTCHES
1 - 6 of 6 Posts
