It's only the belt on the outside of the motor, tensioner is right beside the coolant/washer reservoir tanks. Take a 15/17mm wrench (can't remember which) and pull it towards you, pop the belt off then pop the new one on. If the belt feels a little loose then tighten the bolt that holds the tensioner in place, a little lower than the notch that frees the belt.
