1 - 20 of 25 Posts
So my passenger side headlight went out the other day and I replaced the bulb. I have 6k HID's. I have noticed that sometimes when I'm driving, the passenger side headlight would randomly turn off. If I turn my lights on and off several times, the passenger side light MIGHT turn back on, otherwise it's just pure luck that it ever works.
What's happening? ;[
try switching the ballast form the bad side to the to other side
if the headlight that turns off follows the ballast then you need a new ballast
if not then its probably a lack of power to the ballast
where can i get new ballast? and how much would that cost?
and should there be a direct connection from my car's battery to the ballast? because right now the only connection is the positive/negative connection right by the bulb
check out DDMTuning.com for hid deals
i run a HID wiring harness
Any chance your car's still under warranty? I had exactly the same problem when my MkV was new, luckily got it fixed in the first year then never had the problem again. Dealer tried all sorts of stuff, including new bulbs, ballasts and such then found the entire headlight contraption was just defective and replaced it. Based on the fact that the light works some of the time, I would guess you have a similar problem.
Discussion Starter #6
The car isn't under warranty, i don't think. I'm going to the dealership to get some recall things fixed, but that's all i know.
I'll check the ballast today. For the record, I believe THIS is the kit that's in my car.
Discussion Starter #7
okay i just tried switching the ballasts. the passenger side now has a higher chance of being on, however it still goes out whenever it feels like it; or if there's a bump in the road...?
THALO: how long did it take him to change the headlight contraption and how much do you think that would cost me? is it just the headlight itself or is there more wiring/components to it?
thalo had a mkv with stock HID
you have a mkiv with aftermarket HID system
too very different systems
if the same side keeps going out even after the ballast where changed
its most likely a wiring problem
Discussion Starter #9
...what do i do with a wiring problem? lmao.
dealership...? ;[
check it lol
make sure all the wires, plugs are ok
Yeah, that's right. Didn't bother to check his avatar pic, thought he had a MkV.
Have you checked the terminals on your battery?
Just the other day my hids were flickering/going out and coming back on intermittently
the negative terminal on my battery was loose but after tightening/hammering it down i havent had that problem again.
just a thought
Discussion Starter #13
just a thought
I LOVE YOU. I'm almost certain that's the problem.
My negative cable is hella loose and my only "fix" is putting a nail in between my terminal and terminal tips. i'm getting a new battery cable this weekend, so let's hope that fixes it.
If that isn't is check to see if the wiring harness behind the headlight in loose. Mine was doing what you said until i checked that and saw it was Half plugged in. Fully plugged it in "Click" haven't had a problem since
Discussion Starter #15
Alright so i fixed my battery cable and terminals and that's not the problem.
Today I will try this:
Discussion Starter #16
okay i just tried everything. my headlight doesn't stay on for more than a minute, if it even lasts that long.
any chance this could be the bulb i bought? idk what else to do other than try replacing the headlight itself...
did you try swapping the ballast like i said?
Discussion Starter #18
ok so try swapping the bulbs
Discussion Starter #20
Just got the bulb replaced by a local shop under warranty. New bulb still has problems. Unplugging and replugging positive and negative usually help the headlight stay on, but it goes out shortly after, even when the car is idling and we aren't touching anything. Help???
1 - 20 of 25 Posts
