My 02 GTI started doing this, when you turn the headlights on the dash lights might go on or not, repeated actuation of the headlight switch would get them to go on, but I also noticed that the dashlight dimmer switch was not working as well. Yesteday I disconnected the battery and when I reconnected it and turned the lights on the dash lights came on and the dimmer switched worked, when I turned them off and back on again it went back to what it was doing before. Does anyone know if the dashlights also run through the CCM (Comfort Control Module)?
