Flywheel: A heavy wheel attached to the crankshaft that helps smooth the power impulses created by the firing of individual cylinders. The flywheel also helps maintain the motion of the crankshaft. The outer rim of the flywheel has a toothed ring that is engaged by the starter motor when the engine is started.
