1 - 11 of 11 Posts
Hello, i own a 2009 gti and i recently put in some 55w HID 6000k fogs and now they are flickering like hell for the first 15 min of driving then they are fine. And when i just turn the battery on in the car they are perfect 100% of the time. Is there a way to fix this without a vag-com? PLZ HELP ME!!!
55w 6k is way to bright... just saying
I agree, 6000k is way to bright and downright offensive to oncoming traffic.
As for your problem, sounds like the key thing is the fact the car is starting up, so two things there: temperature and vibration. Maybe something is not quite making a connection, and the vibration makes it flicker, but as it heats up the metal connection/wire expands just a c-hair and its fine. Beats me, I'd say something is fcuked with your wiring, I'm sure it's not the car and you couldn't solve it with vag-com since its an aftermarket accessory.
6k 35W is fine IF they are behind a projector..
Discussion Starter #5
i love em' but ill just get in there and recheck the wiring. it just doesnt make sence that when the car is started they flicker for a bit, and when i just have the electric on they are perfect.
6k is not the brightness of the bulbs
in fact a 6k bulb has less luminescence then a 4k bulb
what affects the brightness is that its 55w
because the high wattage brings a 6k bulb down to like a 5.5k light temperature
thus creating more luminous
Take em to school volcano!
Sent from my T-Mobile G2 using Tapatalk
lol
i hope you guys learned something
lol
Well...
You're right... an under powered metal-halide bulb will leave more mercury un-evaporated, thus leaving a more bluish light, so closer to 6000k or more. Higher powered (more wattage) burns hotter and will tend towards a more white light, say 4500k.
I did not pick up on the higher wattage that PAKNubGTI is running at first, but now it makes sense going from 35w to 55w, so yeah. I'd still be curious to see what the colour temp actually looks like in a pic though, and what the bulb is rated at, might be losing lifespan.
1 - 11 of 11 Posts
