Alright so I hooked up my front mount finally and noticed i only hold 4lbs of boost... Also have a pop in the exhaust, very similar to that of a backfire... The only difference between the fmic and the smic is that the sensor atop the intercooler isn't plugged in. I've reset the battery, checked boost leaks and fixed them, checked the hose going to the dv no cracks or scratches, checked the dv... Only thing left is to retrieve my old sensor, tap a hole and seal/plug it in and check the MAF and the 75 valve... any clues?
