1 - 2 of 2 Posts
So for whatever reason my got some moonroof rattles when tilted. I brought it to the dealer 2X and both times I got no go's. First time they "couldn't duplicate" and the second time it was cause "cars that have moonroofs are not as stable blah blah blah."
So anyways I prefer to take care of this tuff myself. It makes me happy to know that good work is being done on my car.
If someone has this same issue, here is a fix:
Problem---front edge of moonroof rubs on plasti wind deflector making scurenrsr noise---
Temporary fix- wipe down wind deflector and edge of moonroof, lube wind defletor with vinyl lube or other oily substance (that wont get all over)- im using vaseline
Better Fix- if you have had any other rattles or looked around you car you probably have seen the felt tape, apply his tape to the rubbing areas and you should have eliminated the problem.
Mine does the same thing. It really doesn't bother me. Odd at first, but once I understood what it was, I guess it stopped bothering me.
1 - 2 of 2 Posts
