Ok so here is the full story.
Well my car wouldn't start the other day just flat out wouldn't start. I then tada replaced the starter! Well the solenoid clicks and the lights come on fine no electrical interference or anything. The car does not turn on. I checked the relays one of them clicks loudly when I turn the key the 100amp one. This happened over night too. The car ran fine the previous day then the next day I hope in it and BOOM NOTHING. I've been messing with it and the volts are fine and the fuses are fine. It's nothing with the battery because the radio etc works. I cleaned the terminals of the battery cables just in case there was an issue there. The only thing that was done recently to the car was an oil change that's it. My car had been running for about 5 days though since that happened. The starter motor can be manually started by touching the terminals so I know the motor starts. I have no clue what to do I'm getting ready to trade this in on a 2.0T mk5 because I've had so many issue with this car. If anyone has an idea or wants pics of the setup etc. let me know i can get some or explain something else I really need some input.
heres some additional info explained a lil different (from a friend)
I was over to help out with TwichyGTI. Ran fine, the starter was noisy and obviously on its way out. One morning it didn't turn over, so he replaced the starter, now it still wont turn over. 1) The Ground to the starter is good.
2) The Smaller gauge wire is plugged in securely
3) The old starter was sized, Autozone tested the new one and it was good
4) This starter is firmly bolted in, a tq wrench wasn't used, just muscle
5) The starter can be shorted with a screwdriver across its terminals, it spins freely
6) Solonoid and a relay clicks, dunno where relay is, I can hear it.
7) Some high pitched wine can be heard when the car is swiched on.
Maby Twichy can post a pic, if someone could post a pick of how theirs is cabled as well for refernce? I ordered a vag-com cable, it should arrive this week, do you think this would throw some codes?
Anyone have any ideas?
