Camber: The angle between the centerline of a wheel and the vertical, as viewed from the front or rear of a car. When the tops of the wheels lean toward the center of the car, it is called negative camber. When the tops of the wheels lean away from the centerline of the car, it is called positive camber.
GTI wheel actually tilt, which gives you a better footprint going around corners.
