My 02 GTI keeps flashing the red BRAKE light and is beeping at me constantly. The ABS light and asr lights are on as well. Anyone know what the problem could be?
More info. When did it start? Was there anything special about the day it started? Anything weird going on while driving, mechanically I mean? Modifications?
Check fluid level? Check to make sure the ebrake sensor is functioning properly.
Discussion Starter #4
I checked the brake fluid before, and it was full. I took apart the whole center console and the brake switch wasn't sticky or anything. I have my abs light and a yellow light with exclamation point and an arrow around it too, but that has been on for awhile now. The beeping has only been on for two days.
May be experiencing an abs control module failure, or other issues. Anyone local to you have vagcom/vcds?
