What website can i order the New south peformance boost gauge for my MKV. The one that is toward the left side not the middle.
There are several places to put a T in a boost/vac tube. I have the Forge DV kit ready to go in and they have instructions for installing the pressure block on the left side of the engine. I don't have my car in front of me (or within 2,000 miles) so I can't take a picture. It's a pretty beefy line that connects a three-way junction to [I believe] the manifold on the forward-left corner just under the engine cover.Craten said:???...so I'm thinking to myself..."Self, don't start screwin' with that turbo if you don't really know what to fiddle with." So my question is, if I was to get a boost gauge, where exactly does it tie into once I get it all run through the dashboard and get the wires under the hood? I appreciate the help.... O0
I don't have it yet (backordered) but AWE's description says that it keeps the functionality of the vent (though less flow, I'm sure.)DAS FAST said:Will the vent still work despite the Gauge being there?
The thought of losing that vent irks me?
Anyone have it?
i posted that link like 3 up.lumpypumpkin said:Personally, i find the OSIR vent pod to look the best
http://www.zmaxautosport.com/product-desc.php?prodid=156
looks like you would get practically no airflow through the vent tho.
You're asking me?WaZzAp1101 said:kryton, do you like the steering wheel mount kit?
I hadn't seen that OSIR vent pod...that is niiiice.kryptonkid07 said:You're asking me?WaZzAp1101 said:kryton, do you like the steering wheel mount kit?
Well, in my opinion I don't really like the steering mount kit cause it doesn't look... "stealth". I like the AWE vent and OSIR vent set up.
OSIR:![]()
AWE:![]()
definitly sounds like DV and possibly PCVGTiJorgeGTi said:i just install the air conditioning one, but i think before you close it off, you should close off the vent, the vent is open to te ntire dash of the car, might as well close it. the oem air conditionig vent thingy is self contained you take it out it pulls evertthing out, would show you s picj but im at work
BTW, are you supposed to spike to 18 psi, then drop to then when your pushing it? and i drive i loose pressure anytthing above 8, it makes wierd noises and like spikes up and down.. think my dv is crapping out...
