OK, so here's my question, and I'm hoping someone will know if this is possible.
I have 2 good ecu's. One is a 06A906032LP with a APR Stage1 Chip (manual ecu) and the other is a 06A906032HF Stock (5 Speed automatic with tiptronic ecu).
Can I de-solder the APR chip and re-solder it into the Automatic ecu? Will it work, or is the APR chip specifically for the manual ecu?
If it is possible, is their anything I would have to change with the checksum's, programming, etc? I believe APR encrypts their chips, but i'm not 100% sure.
Any help would be greatly appreciated!
Note: Both ecu's are for the AWP setup. But I know you can't change the soft-coding from a manual to a automatic.... Freaking 1.8's
