1 - 9 of 9 Posts
So the other day i was driving around and I noticed that the fan blower wasn't working. The lights were lit up above the deal but no air was being blown out. I searched a bit for burnt out fuses thinking it was something simple. I found a burnt fuse and changed it and everything worked fine. I went in my car the next day and they weren't working again. Does anyone know which fuse controls the blower motor? I have the Bentley book but it's not exactly easy to navigate the fuse panel diagrams in there.
Can anyone offer me some help with this?
Discussion Starter #2
So, after looking again there is definitely a problem with the fuse getting overpowered. I was able to install a new fuse and went for a drive but then it blew out. While sitting in the garage i tried again twice by putting a new fuse in and as soon as i turn on the key the fuse would blow. Has anyone else ever experienced this? Whats going on?
probably a short in the blower resistor or somewhere in the wiring
What size fuse are you using?
its usually behind the glove box
Discussion Starter #9
I pulled the blower motor, removed the resistor and replaced the fuse. went for a drive with the resistor removed and the fuse still blew. does anyone know what else runs on that circuit that could be blowing this fuse?
1 - 9 of 9 Posts
