1 - 10 of 10 Posts
Hello everyone,
After trying everything I can think of besides taking my car to the shop, I am at a loss. My problem started simple enough with my airbag light coming on and then a few days later the steering wheel controls started to work intermittently. After doing a little research I found out the problem was a failing clockspring. I removed the old clockspring (after disconnecting the battery), found out its part number and ordered a new one from 1stvwparts.
CLOCKSPRIN
Make: Volkswagen | Part#: 1K0959653D
I put the new clockspring in (pulling out the locking tab and making sure it did not move position), then put everything back together expecting a fixed car. As usual after you disconnect the battery the esp and steering wheel light came on and the airbag light was still on as well. I took the car out for a little ride as that is usually what it takes to make the esp and steeling wheel light go off, except they didn’t (but the steering wheel controls work again). After doing more research I found out that there was a procedure you might need to do in order to reset the steering angle sensor. At this point I finally bit the bullet and bought a vag-com cable for my car after wanting to for many years. I hooked it up ran the auto scan, reset the airbag light (which is staying off now) and then went about the process to reset the steering angle sensor, only problem was is that I wasn’t getting any reading from the sensor and upon looking at the auto-scan data again I noticed this little error which I can find little to no information on.
00778 - Steering Angle Sensor (G85)
014 - Defective
After that I now have the abs and brake lights on as well as the steering wheel(yellow) and esp. I have included the autoscan log below and left all the sections with error codes though from what I know the engine one is just letting me know that there are problems in the other parts of the car and the speaker ones are because I have an aftermarket amp hooked up to them. I have no clue what the drivers side door lock one is about but it works fine. Does anyone know what could be the problem, my only guess is a defective clockspring angle sensor, but it could be something stupid I did without knowing. If you need any more info feel free to ask. Thanks in advance!
Friday,09,November,2012,16:50:58:57286
VCDS Version: Release 11.11.4
Data version: 20120807
Chassis Type: 1K0
Scan: 01 02 03 08 09 0F 15 16 17 19 1C 25 42 44 46 52 55 56 62 65
72
VIN: WVWHV71K37W234654 Mileage: 84360km/52418miles
00-Steering Angle Sensor -- Status: OK 0000
01-Engine -- Status: Malfunction 0010
02-Auto Trans -- Status: OK 0000
03-ABS Brakes -- Status: Malfunction 0010
08-Auto HVAC -- Status: OK 0000
09-Cent. Elect. -- Status: OK 0000
0F-Digital Radio -- Status: OK 0000
15-Airbags -- Status: OK 0000
16-Steering wheel -- Status: OK 0000
17-Instruments -- Status: OK 0000
19-CAN Gateway -- Status: OK 0000
1C-Position Sensing -- Status: OK 0000
25-Immobilizer -- Status: OK 0000
42-Door Elect, Driver -- Status: Malfunction 0010
44-Steering Assist -- Status: Malfunction 0010
46-Central Conv. -- Status: OK 0000
52-Door Elect, Pass. -- Status: OK 0000
55-Xenon Range -- Status: OK 0000
56-Radio -- Status: Malfunction 0010
62-Door, Rear Left -- Status: OK 0000
65-Tire Pressure -- Status: OK 0000
72-Door, Rear Right -- Status: OK 0000
Address 01: Engine Labels: 06F-907-115-AXX.lbl
Part No SW: 1K0 907 115 H HW: 8P0 907 115 B
Component: 2.0l R4/4V TFSI 0020
Revision: 5BH16--- Serial number: VWZ7Z0G8097444
Coding: 0403010A1C070160
Shop #: WSC 01279 785 00200
VCID: 2B7BE4BD8ADAF640A47
1 Fault Found:
005699 - Please check DTC Memory of Electric Load Controller
P1643 - 001 - - Intermittent
Freeze Frame:
Fault Status: 00100001
Fault Priority: 0
Fault Frequency: 2
Mileage: 79515 km
Time Indication: 0
Date: 2000.00.00
Time: 11:31:21
Freeze Frame:
RPM: 2061 /min
Load: 58.8 %
Speed: 26.0 km/h
Temperature: 39.0°C
Temperature: 9.0°C
Absolute Pres.: 990.0 mbar
Voltage: 14.351 V
Readiness: 0000 0000
Address 03: ABS Brakes Labels: 1K0-907-379-MK60-F.lbl
Part No SW: 1K0 907 379 AC HW: 1K0 907 379 AC
Component: ESP FRONT MK60 0101
Revision: 00H11001
Coding: 0021122
VCID: 73CB3CDD126AEE802C7
2 Faults Found:
014 - Defective
01486 - System Function Test Activated
000 - -
Address 42: Door Elect, Driver Labels: 1K0-959-701-MIN3.lbl
Part No SW: 1K0 959 701 M HW: 1K0 959 701 M
Component: Tuer-SG 005 0987
Coding: 0001205
VCID: 3851CBF14B8C4DD8D95
2 Faults Found:
00928 - Locking Module for Central Locking; Front Driver Side (F220)
008 - Implausible Signal - Intermittent
00105 - Signal Central Locking SAVE/LOCK Drivers Side
Address 44: Steering Assist Labels: 1Kx-909-14x-44.clb
Part No: 1K1 909 144 L
Component: EPS_ZFLS Kl.074 H07 1806
Shop #: WSC 00000 028 00001
VCID: 3449FFC157E4A9B8F5D
1 Fault Found:
014 - Defective
Address 56: Radio Labels: 1K0-035-1xx-56.lbl
Part No SW: 1K0 035 180 G HW: 1K0 035 180 G
Component: Radio PM6 017 0023
Revision: 00017000 Serial number: VWZ5Z7G2138251
Coding: 0040401
VCID: 24690F81E704393865D
8 Faults Found:
00870 - Bass Speaker Front Left (R21)
011 - Open Circuit
Freeze Frame:
Fault Status: 01111011
Fault Priority: 3
Fault Frequency: 3
Reset counter: 204
Mileage: 61851 km
Time Indication: 0
Date: 2000.00.00
Time: 00:14:12
00871 - Bass Speaker Front Right (R23)
011 - Open Circuit
Freeze Frame:
Fault Priority: 3
Fault Frequency: 3
Reset counter: 204
Mileage: 61851 km
Time Indication: 0
Date: 2000.00.00
Time: 19:34:41
00872 - Bass Speaker Rear Left (R15)
011 - Open Circuit
Freeze Frame:
Fault Priority: 3
Fault Frequency: 3
Reset counter: 204
Mileage: 61851 km
Time Indication: 0
Date: 2000.00.00
Time: 18:26:32
00873 - Bass Speaker Rear Right (R17)
011 - Open Circuit
Freeze Frame:
Fault Priority: 3
Fault Frequency: 3
Reset counter: 204
Mileage: 61851 km
Time Indication: 0
Date: 2000.00.00
Time: 19:34:41
00874 - Treble Speaker Front Left (R20)
011 - Open Circuit
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 207
Mileage: 84360 km
Time Indication: 0
Date: 2000.00.00
Time: 14:29:08
00875 - Treble Speaker Front Right (R22)
011 - Open Circuit
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 207
Mileage: 84360 km
Time Indication: 0
Date: 2000.00.00
Time: 14:29:08
00876 - Treble Speaker Rear Left (R14)
011 - Open Circuit
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 207
Mileage: 84360 km
Time Indication: 0
Date: 2000.00.00
Time: 14:29:08
00877 - Treble Speaker Rear Right (R16)
011 - Open Circuit
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 207
Mileage: 84360 km
Time Indication: 0
Date: 2000.00.00
Time: 14:29:08
End ---------------------------------------------------------------------
What did Ross tech wiki say?
Sent from my SPH-L710 using Tapatalk 2
Using the ross tech wiki I had found this page http://wiki.ross-tech.com/wiki/index.php/00778 but it does not have the code 014 - Defective that I am getting.
To provide some more information referring to some of the general troubleshooting options on that page. "With steering wheel level, wheels pointing straight ahead, make sure G85 is reporting 0 degrees +/- 5 degrees. If a reading of +360 or - 360 degrees is found. Remove steering wheel and turn clock spring 1 turn in direction needed to fix. See repair manual." On my car it is reporting 0 but that is only because it is not receiving a signal at all.
Later on down the page there is this. "Check Steering Angle Sensor (G85) Installation Position" I do not quite understand this, is this just another way of saying the same thing as my first quote, that the clockspring was installed out of center or is it referring to some other way the steering angle sensor can be positioned that I do not know of? Am I correct in thinking that the steering angle sensor is inside the clockspring?
Discussion Starter #4
Originally Posted by MK5CNY
Here you go...hopefully it's that easy for you.
http://forums.vwvortex.com/showthrea...g-assist-light
I tried the tire pressure idea as a long shot to no avail. I have done the procedure listed on that page many times and in many different forms that can be found throughout the ross-tech wiki and they never do anything.
I am pretty sure the answer lies in figuring out what "00778 - Steering Angle Sensor (G85) 014 - Defective" means. In an attempt to try a few more things for myself, I installed the old clockspring again and I am getting the same errors for it that I am getting for the new one (in addition to old problems that clockspring had). This leads me to believe that the problems has to be either in another part of the car (how is that possible when nothing was done outside of changing the clockspring and everything was fine beforehand) or that there is some weird activation that needs to be done when replacing a new clockspring that is not listed anywhere.
To help out a little bit more following these directions in the ross-tech wiki
Adaptation
Basic Setting
Sensor for Steering Angle (G85)
Prerequisites:
Start the vehicle.
Turn the steering wheel one turn to the right and one turn to the left.
Drive in a short distance straight line on a level surface at a speed not higher than 20 km/h.
If the steering wheel is straight during the test drive then stop the vehicle with the wheels pointed straight.
Ensure that the steering wheel is not moved again.
Keep the engine running and do not switch off the ignition.
System voltage at least 12.0 V.
[Select]
[03 - Brake Electronics]
[Measuring Blocks - 08]
Group 004
[Go!]
Check field 1, the value has to be between -1.5 and +1.5 °.
[Done, Go Back]
[Coding-II - 11]
OR (if Coding-II is not available)
[Security Access - 16]
Enter 40168, to enable the basic setting.
[Do it!]
[Basic Settings - 04]
Group 060
[Go!]
After a successful basic setting, field 2 should say "OK".
[Done, Go Back]
[Close Controller, Go Back - 06]
Under group 4 I have 0, which is ideal but in this case it is just showing that because the sensor is reading nothing.
Under group 60 it says, Field 1 (Adjustment) Field 2 (Not Possible) Field 3 (NA) Field 4(NA)
Logic tells me that if the sensor doesn't supply a signal, the sensor is bad...
Discussion Starter #6
So after looking around the internet for way to long I gave up that approach and started taking apart my car more. I found out the sensor is not part of the clockspring but a small piece directly behind it. The only way I found this out is by taking it out and looking up the part number. There really isn't much information out there regarding this problem as well as the clockspring and sensor in regards to the gti/golf mkv. The part is in the mail now and here's hoping that this will be the end of my problems. Thanks to all of those who helped me.
Hi,
I have the same problem, Did You Figure It Out?
BEST REGARDS
Discussion Starter #9
Hey,
Sorry for never following up on this, other junk happened in my life and it didn't cross my mind till I was going through the threads today. After receiving the new steering wheel sensor, it just slides into place (getting the old one out was another story and I can't even explain how to get it out properly, a small hook and time mixed with cussing) I then put the rest of the steering wheel back together and the problem was fixed. (I had done a lot of troubleshooting with vagcom and had to do a steering realignment test and reset the brakes/traction control but I think that was all vagcom related and my own fault, I don't think you would need to do this if you just replaced the part)
I hope this helps anyone that may have this problem, all in all its a very easy fix and so is the clockspring if you need to do that at any time as well.
Hello everyone,
I have the exact same problem on my 2003 Jetta 1.8T. I have tried taking the sensor apart and cleaning it but did not help. I notice there are 4 photo sensors inside and 4 photo emitting diodes (infra red) that are used to monitor steering wheel movements. I have experience with electronics, but still need more information in order to troubleshoot this particular issue. The VCDS is reporting that the sensor is Defective! The sensor has 6 pins and I have not checked if the sensor even has the supply voltage (I assume it should be +5V and GND on two of the leads). I have ordered a replacement and we will see if that is the problem or something else. I will post in a week when the sensor arrives. It would be nice to actually fix the sensor. It appears to be very expensive.
Hope this helps someone...
1 - 10 of 10 Posts
